roaming | What combine are you getting? I take it it wasn't ordered guidance-ready?
What tractor will you be planting with? The Pro600 currently works only with new Magnums and Steigers, I believe.
Why won't guidance work for you in row-crops? Are you thinking your rows - manually driven - aren't as straight as they could be, so the autoguide will be too good when you try to use an autoguidance combine on manually-planted rows??
What signal are you thinking of using?
Edited by torn 3/2/2007 20:59
