Search Forums | Classifieds (28) | Skins | Language
EZ-STEER ON IH 2+2 6788?
daveb
Posted 2/19/2007 10:37 (#107414)
Subject: EZ-STEER ON IH 2+2 6788?
Fargo, ND
I'm reposting this because I should have put more information in the subject line so you would know this is a precision ag. question rather than a tractor question.
I have a customer who wants to install an EZ-Steer 500 on one of the older IH 2+2's. Trimble doesn't make an installation kit for this tractor or list the settings for it. Is anyone using an EZ-Steer on one of them? If so, do you call it a 4WD or a 2WD tractor in the setup menu? Where would I install the antenna? This tractor is different because the cab is behind the articulation joint and it doesn't move with the front axle like a conventional 4WD. Thanks for any input.
