39.48, -82.98 | After logging in at AgTalk+, click on My Account (at left) and Edit tab. Scroll about 80% of the way down the page and look at the two monitors. You probably need to select the top one (and Save, at bottom), which will change your theme to Fixed. (Users with wider-aspect monitors should use the default Fluid theme.) If this doesn't solve the problem, check your screen resolution. It should be a minimum of 1024 x 768. Even this four-year-old version of AgTalk recommends that. 800 x 600 was OK for 15" monitors but we no longer design for it.
