| moonshine - 1/29/2007 20:56
Any gossip about improved functionality? Like improved curve following?
I had the chance to have a quick go with the EZ Guide 500 and EZ Steer T2 the other day. I think you will find the functionality an improvement, especially as the user is able to choose between the easy mode and advanced mode. This basically dictates whether or not you want to just create AB lines or create Grower, Farm, Field type information. Another neat touch is the logging options. This can be on all the time, connected to an implement switch or work when the EZ Steer is engaged/disengaged. There are other features to that I think will improve and streamline operation.
However, the biggest improvement is the curved line following. Whilst it is not an Autopilot, it is a vast improvement over its predecessor and I think most will be impressed.
I can't wait to have a go in a more field like environment!
PER |
