| Internet Explorer 6
Export:
Click on File> Import and Export. This will bring up the Import/Export Wizard. Click on Next. Select Export Favorites from the list and click on Next. Select the top folder called Favorites to export all your favorites and then click on Next. Click on Browse. This will bring up the Select Bookmark File dialog box. Click on the Save in: drop down menu and select the drive letter of your flash drive. You can name the file you are about to create or just leave the default file name of bookmark as the filename. Click on Save. Now you are back at the Import/Export Wizard. Click on Next. Now click on Finish.
Import:
Click on File> Import and Export. Click on Next. Select Import Favorites and click on Next. Click on Browse and select the drive letter of your flash drive from the Save in: drop down menu. Select the file you just saved to the flash drive and click on Save. Click on Next. Select the top folder named Favorites to import all your favorites into this folder. Click on Next and then click on Finish.
If you are not using Internet Explorer 6 post back with what you are using. | |
