Posted 1/5/2010 23:42 (#1005643 - in reply to #1005629) Subject: RE: Do you heat your .....
Unless I am moving around much in my house, I tend to keep my thermostat somewhere around 60-62 deg F.
Then I have 2 small portable electric heaters (I think they are rated around 1500 w - I bought one at Home depot, and the other one at Target.) I use these to heat the two rooms that I most often use - heat them up to around 70 deg F. or so.
