| This is something I have been experimenting with using an Agleader Insight along with a fuel flow meter & mult product unlock.
While drilling spraying etc i have been controlling the rate etc & logging the fuel flow & usage. In principle it does everything you want, I have been using relatively inexpensive flow meters that have proven unreliable.
If only we could tap into the Can-Bus on modern tractors & log the flow from there....... | |
