North west MN | I think the autopilot would work. also I have never had trouble with the trimble 900 mhz radio signal around trees and I am getting more than the advertised 6 mile radius. If you get right under a tree you might lose a few satellites though. The biggest problem I see in row crops is getting everything centered if you plant and the planter is drafting 2 inches to the left it is hard to repeat that in a sprayer | |
