Search Forums | Classifieds (18) | Skins | Language
Why Anti-Diabetic Drugs Usually Make Things Worse
BigNorsk
Posted 5/18/2024 16:54 (#10744045 - in reply to #10743670)
Subject: RE: Why Anti-Diabetic Drugs Usually Make Things Worse
Rolla, ND
What kind of makes me mad is the eople who insist that once diabetic, always diabetic.
Often followed by if you go back to doing what caused the diabetes the first time it will come back. Well by that reasoning, I was born diabetic.
Many type twos are capable of making several times the insulin necessary for a healthy person. Why continue being disbetic?
There are many cases where the damage was too much to get back to optimum but cases of pancreatic recovery are being documented.
Could just as well argue if you cut yourself once you are always cut because if you run that knife across your arm, you will start to bleed again.
