southern iowa | Had a remote throwing aux hydraulic fault when in constant flow after a bit, not sure about momentary. Replaced the armrest hydraulic control switch but that didn't fix it. Dealer is suggesting maybe some hydraulic slider is acting up. I am wondering what the proper name is for that slider? How hard is it to change? Maybe it is a wiring issue? Takes a bit for the fault to show up then it soon becomes unusable no matter whether the tractor is restarted or not. Thanks | |
