Galchutt, ND | Have a 6000 receiver on a 8520t It will kick out the autosteer due to a loss of can communication with the receiver. Usually as fast as I can cancel the error the 6000 is back on line and working again but it will do it multiple random times through the day. I have watched the voltages on the HI/LOW can on the 2630 display and the low can voltage on the 6000 diag. page will creep up to 3.5 or higher and then loose communication. When I go to the screen diag. page the Imp can low is reading 5.5 can hi stays around 2.4-2.6. When its working voltages are 2.4 on both hi and low can. Replaced ISO coupler in back and it still does it. What else should I be looking for? | |
