North Dakota | If you are on 1.9 the 750 should be updated to 8.2. I'm not sure if 1.9 is able to use a remote engage. To update you will need to do it in steps up to 2.x then 4.x then 7.x and finally to 8.10. When you get to 8.10 you need to do a hard reset and it will change the format of the memory so it doesn't give memory full errors as fast.
After updating you need to turn remote engage ON in the engage options page.
edit: Link to download files for updating including update for the monitor if it isn't on 1.17
https://vantagenortheast.com/manuals-firmware/
https://www.dropbox.com/s/i0o6gsszi2n0t90/CFX%20Firmware%20steps%20V...
Edited by raider2b 4/24/2024 06:26
