Search Forums | Classifieds (158) | Skins | Language
JD1775 Hyd ?
IH_always
Posted 4/23/2024 16:29 (#10716358 - in reply to #10716347)
Subject: RE: JD1775 Hyd ?
Probably around 1400 RPM's while turning and lifting planter. Tractor has new remote couplers and do not leak. Would the male tips on my planter be the cause? I guess the cylinder are large and take some oil to fill them and the planter is heavy. Why does JD put a large hyd hose on the lift system with a regular size male tip?
Edited by IH_always 4/23/2024 16:32
