4555 Alternator issue
Kyfarmer07
Posted 4/23/2024 15:54 (#10716329)
Subject: 4555 Alternator issue
Having A issue where my Voltage light is coming on and the alternator only putting out 11.5 same as the battery is on the right side. If goes down stays with it.. Check the batteries they are fine Had the alternator looked at it was fine, but then decided to go on and buy a new one just to try cause I wasn’t having any luck. Tried Replacing new bolts in the alternator to make sure it was grounded, correct still reading same. Any ideals.
Wondering if the stater relay has anything to do with it?
