Search Forums | Classifieds (13) | Skins | Language
CASE SPX3330 with internal WAS and AgLeader
sat5
Posted 4/23/2024 09:12 (#10716216)
Subject: CASE SPX3330 with internal WAS and AgLeader
My sprayer CASE SPX3330 is equipped with Ag Leader with an external wheel angle sensor. At the same time, there is an internal sensor with 3 wires on the right steering cylinder this lable "auto guidance steering sensor". I tried to connect an internal sensor instead of the aglider sensor - in this case, there is a voltage of 3.6 volts at the signal output of the sensor, regardless of the position of the hydraulic cylinder rod. How can I use an internal sensor with an AgLeader ? Maybe it is necessary to use some other inputs on the SCM?
