NE Nebraska | I’m sure it is some, but with the wind usually blowing up there and no way to seal the door permanently shut, there’s only soo much I can do. I just clean it up with a shop vac when I clean up the dryer. Maybe a gallon or less of dust. I also get dust in when I have to open the door to unplug the air pipe or just check anything. I blow the air filter on the blower out once per season instead of daily like a neighbor does with his about the same distance from the dryer. | |
