twraska - 4/17/2024 16:08
SP49047 - 4/17/2024 09:45
What did you gain from EkoTune? Did it affect your warranty at all? Has JD done an over the air update and the tune stayed in place or did you have to redo it? I have been doing some research on different avenues and have heard several different pros and cons to both power mods and ECU flashes
So…. If you’re not affiliated with Steinbauer, are you affiliated with the EPA or some other federal agencies trying to bust someone for using a tuner?
