North Central OH | Would have to look at ours but don't think there is a clutch, do believe its a viscose fan type. If I remember right generally the fan should turn stiff if you walk try it cold, if it freewheels might be bad. Could try to heat it and see if it locks up. Is the fan belt good? Only time ours overheated the fan belt gave out for no reason, for some reason my dad didn't notice the other warnings till the high temp one came up. | |
