SE SD | Wasn't to risky of a burn. Had a burn plan in place, and followed the prescription. Was a clam day, would of been better with a 10 mph winds. Had 7 guys on the burn. Put in black line in the morning humidity was around 50% and temps were in the upper 40s so spot fires were not much of a concern. Also had a spot fire forecast from NWS for this specific location. After the black line was in , strip head fires and finished it off. had good fire breaks in place. Some natural, roads, and disked fields. Wanted to do this burn first, because south of this they have a bigger unit with a lot more vegetation, and more cedars. This unit will act as firebreak for the south unit. | |
