Central Iowa | Have a 2310 soil finisher we have been fighting streaks or almost plowing in some cases. Implement is level, we tried adjusting the harrows on back didn’t help. Pulling it out of the ground didn’t seem to do much either. We normally run the disc gangs in front all the way in the ground otherwise the finisher will start to bounce if you run them any shallower at the speed we are trying to run it at which is 7.5-8.0 mph. Wondering if we should change the sweeps to something different. It currently has the 10” sweeps which I believe come from the factory on them. The set we have on our brand new. What is everyone running on a finisher for sweeps that you are happy with? Maybe the 10 inch is to aggressive? Any info is appreciated | |
