SE Iowa | So using a different tractor for planting this year which is a New Holland T7.245. It has four hydraulic remotes so I but the bulk vac on the far outside (4) and just let it run and push to float before shutting off. I locked out reverse and needs about 20% output to maintain 12in/h20. Seems easy enough. Now sometimes when lifting the implement i don’t get the lift remote (1) back to neutral before it shuts down. So I got better at doing that. Then sometimes if lifting, clutching, and braking the tractor it would occasionally shut off then. I would say it is when hitting the brakes harder than typical is when it happened. Why does it shut off and is there a way to avoid it? | |
