Holly Hill, SC | Had very similar problems on my JD 4730 sprayer. (I know it is not the same machine) Replaced all 4 of the terminators on the CAN bus wiring. May help to pull up the parts book on your machine to search for all of them. Attached is my older post on my problem and at the end the solution. My sprayer has been running great ever since. Good luck fixing your problem.
https://www.newagtalk.com/forums/thread-view.asp?tid=1069531&Display... | |
