Posted 4/9/2024 20:56 (#10700961 - in reply to #10700472) Subject: RE: 2210 Harrow settings
SW MN
Book should show how to check pressure. End of tines should be certain distance from bottom of shovels deeper. We clamped board on bottom of shovels and set pressure of drag per spec and the adjust angle depending on trash. Also measure tines as some wear more. Once we set pressure and put new tines on it should level good
