Posted 3/28/2024 05:58 (#10683590 - in reply to #10683238) Subject: RE: Westfield auger cylinder
WC Ohio
There should be a stop at the upper end. It is just a piece of angle iron bolted across the track. If the auger is set up correctly it should be against it when lowered.
As for removing the cylinder I haven’t found a way that doesn’t suck. It is just heavy and awkward.
