Clarendon NC | tractor is leaking hydralic oil around a small shaft on the left side of transmission this is a 24x24 tranny and the shaft is behind the fuel tank and there are 4 coils in front and a support for the fuel tank close to the coils can the shaft be slid out to replace the replace what looks to be orings on the parts diagram or do you have to take everything in front of it off first Thanks in advance | |
