Southeast Washington | Your 110 gpm pump is actually twin 55 gpm pumps. Half the remotes are configured on one pump and the other half were on the other pump. Did you have your remotes split evenly to load both pumps or did your have one pump heavily loaded? How did it work for your? Need a little more information as to how you had each pump set up to run.
If just the standard remotes you can't get much more than 25-28 gpm through one half inch remote. How many do your run or are your using the power beyond ports? | |
