Search Forums | Classifieds (41) | Skins | Language
VRT on a HYD driven spreader box with manual gate adjustment?
gpsdude
Posted 3/27/2024 21:11 (#10683367 - in reply to #10682845)
Subject: RE: VRT on a HYD driven spreader box with manual gate adjustment?
NE South Dakota Clark, SD
I always recommend the best signal you can justify for everything including the combine if you want good yield data. Most people will vary the belt speed for VR with a fixed gate opening. Different products may need different gate opening to account for the amount of product being applied. I have worked with people using the gate opening to control rate with a fixed belt speed. This only works well on very simple RX maps with only a few different rates.
