We bought a JD1560 drill with a two pint hitch and plan to use a MF 6180 tractor to pull it this spring. Only problem I can see is that the tractor two point hitch is Cat II and the drill two point hitch pins are Cat III and too big to fit on the tractor. Is it possible to switch or the pins on the drill to fit the tractor?
