Posted 3/27/2024 10:21 (#10682502) Subject: Magnum 215. What hydraulic remote valve parts do I need?
West-Central IL
Have a magnum 215 where remotes let the implement leak down fairly quickly.
I suspect several are this way from running in continous flow for pull type sprayer boom supply and pump supply. With that implement the issue was never really noticed.
I have been told I need a "barrell" replacement for each remote in the stack.
Is this correct advice? What part # would be he correct kit to look for?
