Search Forums | Classifieds (2) | Skins | Language
2022 Case tractor w Pro 700. Jd rate controller/ Fieldview
plowboy2
Posted 3/24/2024 21:16 (#10678732)
Subject: 2022 Case tractor w Pro 700. Jd rate controller/ Fieldview
Have a 2022 Case tractor with Pro 700. Running a JD rate controller (2630) for NH3 bar. Using the GPS from the case globe. Having a hard time getting Fieldview to work. I purchased CC1081K harness from Ag Express. It has the connecting port for the Fieldview drive. Plug it in and still the Fieldview drive does not work. With that particular setup do I need the Actisense module from Climate to get the Fieldview drive to work?
