IA | For the AB lines I’d say it somewhat depends what your goal is. Do you want to be straight with one side of the field/fencerow or make sure you lay out correct to some terraces or have the correct angle for how the field lays out but not the same as any one side of the field? The one nice thing about having the guidance lines before you are planting is if you are using straight AB you can autosteer the first pass and have it be just as straight as the next ones so you don’t have any narrow or wide spots when it draws a perfectly straight line | |
