Search Forums | Classifieds (193) | Skins | Language
JD GS3 Too Many Implements Connected
JAnderson
Posted 3/24/2024 07:14 (#10677505 - in reply to #10677489)
Subject: RE: JD GS3 Too Many Implements Connected
McCanna, ND
If it’s factory John Deere seedstar (pick your flavor here) that software isn’t true ISO, they just use the CAN network. I would ditch the splitter, don’t see how that would work. You should be able to take a terminator off the end of the Deere planter harness put the muller ecu on where the terminator was then install the terminator after the mueller, that’s how a true ISO system should be wired. I run 2 ISO controllers on one screen frequently, and believe I’ve ran 3 before.
