Parker, SD | So after some conversation with AgExpress. I did have the receiver connected correctly and it was communicating with the radio. We discovered that the antenna was faulty causing no actual RTK connection. CMR 0% replaced the antenna and got 95% CMR and everything works correctly, and it still shows no radio on the GPS tab. I'm guessing this is a result of the older 252 receiver. We have the lastest firmware in the radio and receiver. | |
