Posted 2/29/2024 18:32 (#10645810 - in reply to #10645733) Subject: RE: Trouble with steer command z2 calibration…
Midwest
fox128 - 2/29/2024 17:16 Well it passed WAS cal fine. Same WAS I was running with the legacy steer command, I switched pins an and c per the instructions. I have not double checked counts but I know I had it dialed when I did the legacy cal a few years ago
You have to switch pins between versions of the same system? Yikes
Crazy the % would actually go down on the progress bar. Also weird/yikes
