Search Forums | Classifieds (182) | Skins | Language
Field Setup
   Forums List -> Drone TalkMessage format
TrussServicesLLC
Posted 2/25/2024 20:18 (#10639958 - in reply to #10639244)
Subject: RE: Field Setup
North Central Ohio
I have had good luck just using the google earth imagery versus pre-mapping. I have tried both and I have found that it works perfectly fine without doing the pre-mapping. The only time I would pre-map is if I am spot spraying, doing work on hilly terrain or anything needing precise application.
