Hennepin, IL | Do you have a flow meter? If so, it really shouldn't matter. If you have both a flow meter and pressure sensor, it might honk at you that pressure and flow are out of relationship is all. If you were set up to use pressure for feedback instead of a flow meter, that's where you would technically need to change that density number. Funny story though, I had a Hardi sprayer setup that way and changing density didn't matter. I ended up having to switch the pressure cal # when I changed between water and 32%. It made no sense to me then or now, but that's what I did and it would work great. | |
