Posted 2/18/2024 10:15 (#10628526 - in reply to #10628347) Subject: RE: Cheap way to “try” 2x2 or 2x0 on planter? Need some ideas from fellow tightwads
Central Alabama
I use the JD post spray band kit on mine with a 3-hole streamer tip. Then I put a stainless-steel screw in the center hole.
If I did not already have this would have gone with the tube.
