Posted 2/14/2024 06:01 (#10622684 - in reply to #10622658) Subject: RE: Is it too early to topdress winter wheat in NW IL
Scottville, 49454 Northwest Michigan
If your wheat is well-tillered.... I would wait until after greenup. But if your wheat is a little weak on the tillering... than the only reason not to, is if you think you'll get precipitation that will cause the fertilizer to run off your fields.
