Search Forums | Classifieds (2) | Skins | Language
AgOpenGps and wheelman
WildBuckwheat
Posted 2/11/2024 11:25 (#10618708 - in reply to #10618266)
Subject: RE: AgOpenGps and wheelman
Middlesex County, Ontario
I'm not that familiar with the Wheelman systems but from some searching I've found that
There's no AgOpenGPS converter program that is going to talk directly to the Wheelman system like the phone app would.
Wheelman doesn't do RTK, at all. The only way to communicate with the system is through the Whirl app, and the Whirl app won't deal with NTRIP. So you aren't going to be making a DIY base station and using it with the Wheelman system.
The motor is built into their little lightbar/computer shroud thing. You aren't going to be bypassing everything and directly interfacing with the motor through an external plug. If it's possible to bypass everything and connect straight to the motor then you are going to have to open it up and so some soldering, and hopefully its a simple DC motor and not a stepper or BLDC motor.
Its not that it can't be done, it just hasn't been done yet and there's no how-to guide for you to follow.
