| If you were going to put a 1630 Geringhoff head on a X9, would headsight horizon with header height and true sense auto pilot be best, or should I just go with the Deere setup. I was using this head on a lexion 760TT before with headsight insight but was told I need to go to horizon for the X9. I plant with a 24 row planter and split the odd row in the middle of combine every other pass so the headsight sensor feeling off 2 rows did a good job evening things out on a narrower or wider row.
Edited by tex 1/30/2024 21:00
