Southeast Illinois | We've been running Active PDF only through the tractor screen via ISOBUS. The first image is what we used to see on the screen. You could cycle through the various SeedstarXP functions using the icons in the bottom left. Once on the downforce screen, you could set your target margin and then check "Active PDF" to start the compressor and the system would automatically add & remove air from the bags to maintain margin.
Picture 1 is the screen we would see when it was working properly.
Last spring we pinched the harness on the planter main frame going back to the PM1/PM2 boxes. We repaired the harness, but we cannot get some SeedstarXP functionality back. We no longer see the icons in the bottom left and cannot set PDF margin or enable Active PDF.
Picture 2 is what we see now.
Seems like we've lost XP functions and somehow reverted to Seedstar2. I've tried swapping the PM2 module with another PM2 module with no success. Do I need a new PM1 module? Or what is going on?
(PXL_20220118_172106555.MP (full).jpg)
(PXL_20240130_152357914 (full).jpg)
Attachments ---------------- PXL_20220118_172106555.MP (full).jpg (190KB - 41 downloads) PXL_20240130_152357914 (full).jpg (160KB - 35 downloads)
