Posted 1/31/2024 05:40 (#10601607 - in reply to #10600061) Subject: RE: XCN 1060 to climate
northeast ohio
IF the round 5 pin port on a XCN1060 is the same as a XCN1050, then there are two cable options to consider. Pinout diagrams are included in these links.
A couple of years ago, we made up a FieldIQ and accessory cable for our XCN1050 from a 92676 TMX Harness. For the wires that needed to go to the 5 pin, I believe it was a Phoenix 5 pin plug with B code style insert. M12MSB-5CON might have been the description used to find it. Not sure if 1060 is the same.
