NC IA | Works great, awesome for inhibiting 32% volatizing, stabilizes the salt so you can safely spray it over emerged corn, changes the UAN pH so herbicide works better. Runs between $670-700 a ton, so $3.80 a gallon. Typically spray 5 gallons with 50 gallons of UAN. Not much more per acre than Instinct and you're not putting a chemical on the field that effects your microbiology.
I haven't used it in post passes at this point in time, but I will this year. If I can remove Class Act and Interlock, and gain plant health that is a big win.
Works good with 6-24-6 or 3-18-18 as well if you run liquid starter.
Edited by npschaps 1/25/2024 08:40
