Alton, Ia | This is a longshot......
Have a partial slat, pull plug barn, where you remove one slat gang to get to the plugs. Works okay, have a helper who struggles with the weight of the slat gang. Is anybody aware of a single gang plastic slat, prob 5" thick, 10 ft long, that one could drop in instead?
Looked at making a stainless rod/hook system, unfortunately a couple of the rooms the slat is directly over the plug.
Talked to local hog equipment gang, suggestion was to remove concrete and replace with plastic sow flooring, nah, don't intend to feed long enough here to justify that.
Any ideas? | |
