Posted 1/23/2024 19:18 (#10590051) Subject: JD Auto Pass on a Precision Planting Planter
SE North Dakota
Is anyone running a Precision Planting planter and using John Deere Auto Pass? How did you make it work? I do not have a JD Rate Controller on the planter, so can’t use a lift switch. I cannot use SCV 1 has a trigger for planting since the remote is in constant down or up. Any way to make this setup work? Thanks.
