Posted 1/22/2024 23:25 (#10588734) Subject: H-1000 tub grinder feed issue
I have a late 80’s h-1000 hay buster serial-8602185 That keeps plugging up on the grind side of the mill between the screen and the side wall (grinding mostly crested wheat hay) . Mill has new rods and hammers as well as new screens 2” grind 3” clean out( less than 200 bales). The augers are wore down to 8-3/4” thought that was my issue so I built up the grind side auger 1/2” which didn’t help.
