Posted 1/20/2024 19:55 (#10584858 - in reply to #10583422) Subject: RE: Ez guide plus power pinout
Central ND
This should work for you. It has a few extra plugs and pins for the ez steer connection but does show the power and ground for the 4 pin connection to the ez guide plus.
Looks like tip of the plug would go to pin 1 and then the ring/side of the plug would go to pin 3.
