East Central, Nebraska | i would think you would need a strip till module to run the dry box. you could run 2 liquid modules for the nh3 but i dont remember for sure if ag leader will utilize microtrack controls or not. i think older hiniker was one of the only ones it will not work with. as for multiple modules it is not a big deal at all, just add them to the can line and make sure it is terminated correctly. you will also need a multiproduct unlock on the display, which is not standard on any monitor, to run multiple products.
the more i think of your nh3 situation you may only need 1 module for that. a second would definitely do it but i am unsure how the configuration would be setup if each module is only running half widths. | |
