NE Indiana | With the bigger screen of the gs5 Plus is it now possible to have split screen between guidance and ISO screen. I remember at first with the 4640 you could only have ISO on the page. and then later they let you put a little map up on the same page but was basically useless because it was so small. I have been running a 4640 and an extended monitor to fix this problem. We are going to a G5plus display and just wondering if I need to get a G5 extended display or if there is enough room on there to have the ISO screen and a decent sized map up at the same time. | |
