Bavaria/Germany | You should try to change the settings on F9P
I dont what your Cors network does transmitt?
RTCM 3.2
GPS, Glonas, Glileo and Beidu
Anyway, you should disable Beidu in the F9P settings than it should be OK so far.
But its only my experience with the F9P chiset here in Europe. Several EU countries (Lithuania, Pland, Germans, Austria etc.) give although free government RTK service.
Mostly RTCM 3.2 3G (GPS Glonas and Galieleo)
Some already ERCM 3.2. 4G (GPS, GLonas, Galileo and Beidu)
It works just fine with most brands of Receivers. But the Ublox F9P does struggle sometimes! As you need mostly 10hz for Autosteer, the F9P is going very often (specially after some time when its going hot) back to only 8Hz and so Autosteer makes problems.
Out of my experience, disabeling Beidu does help a lot! | |
